928 Forum 1978-1995
Sponsored by: 928 Specialists
alternator ills
Old Oct 13, 2008 | 01:36 PM
mj1pate's Avatar
mj1pate
Default alternator ills
Having watched my alternator voltage output drop (over time) closer to 12 volts under load, I checked the options via the postings. I opted to go the parts replacement route as the least expensive option. The voltage regulator and brushes are an integrated unit and are easily accessible in the back of the stock alternator. The regulator/brushes cost ~$60.0 as a Bosch part or $9.99 as a wai-wetherill part. I replaced the two parts, and as usual, remounting the alternator was the biggest pain in the job. Yes, I used the wai-wetherill part and no load is just over 14 volts and full load is just over 13.5 volts. Very cheap fix for what ailed the alternator. With the modest miles that I apply, I expect this to last a long time. If I was planning another cross-country, I would would carry a spare VR-brush assembly in the glove box.
Old Oct 13, 2008 | 05:29 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
can you please have more detailed explanation of where you got the parts Brushes thanks . Glad is all fixed,
Old Oct 13, 2008 | 06:28 PM
devilinblack's Avatar
devilinblack
Yes, I'd be very interested in some details as well since my voltage seems to be down a bit lately.
Old Oct 13, 2008 | 11:04 PM
mj1pate's Avatar
mj1pate
here is the link: http://www.wai-wetherill.com/products/ymm.cfm
Old Oct 14, 2008 | 01:30 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Here's another source:
http://oem.thepartsbin.com/parts/the...lator&dp=false
Old Oct 14, 2008 | 01:54 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Bill I looked at the voltage regulators that you posted , do they look like Bosch part to you?? It says Bosch on the bottom of the page but the part doesnt look like Bosch part to me
Old Oct 14, 2008 | 02:11 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
The picture may be a general stock image.
Old Oct 14, 2008 | 01:22 PM
Jfrahm's Avatar
Jfrahm
I have posted this link before, I think I found it here, actually. It's a neat trick that mods a stock vreg for a little more juice:
http://www.detomaso.nu/~thomast/alternator/
I would not do this to a tired old regulator/brush assembly but an extra .5 volt would b e nice, and this is less fussy than an adjustable regulator.
-Joel.
Old Oct 14, 2008 | 02:01 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Thanks for posting this Joel
