928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel sending unit removal
Old Oct 12, 2008 | 05:28 PM
Rod Underwood's Avatar
Rod Underwood
Default Fuel sending unit removal
I drained my tank today to see if there was anything - bad stuff - in it and I could lift the fuel sending unit up just enough to see in, but it didn't want to come out. Could someone tell me if there is a trick here. It seems as though it should just lift out, but it won't and since it works perfectly now, I didn't want to "fix it till it was broke." I did!
Rod
Old Oct 12, 2008 | 05:41 PM
SharkSkin's Avatar
SharkSkin
There is a "cup" on the bottom of the sender, and it fits closely through a hole in a "slosh plate" near the bottom of the tank. Maybe it's hanging up on the slosh plate. Try wiggling it around a bit as you gently pull upward.
Old Oct 12, 2008 | 05:43 PM
jpitman2's Avatar
jpitman2
Rod, Mine has done this too. DO as Dave suggests - wriggle and jiggle, it should come out...
jp 83 Euro S AT 51k
Old Oct 12, 2008 | 05:45 PM
SeanR's Avatar
SeanR
Yup, it should lift straight up and out.
Good job on draining the tank before doing it. Just never pull one with a full tank. WSM says to have at least 5 gallons from full before doing so. On one, I pulled one out and didn't know the tank was full. That was not fun at all.
Old Oct 12, 2008 | 08:40 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Sean nothing like cleaning the out side of the tank while its still in the car.. Glad you didnt get burned
Old Oct 12, 2008 | 10:32 PM
the flyin' scotsman's Avatar
the flyin' scotsman
Rod...........I have a recent thread on the sender with pics............it lifts straight out; getting it back in is a little fun
