tachometer stopped working ???
This morning, my Tachometer stopped working om my '88. Everything else works fine (in fact, the stop light sign is on also ) speedo, fuel gauge,voltmeter ,etc...
I removed the cluster check and clean the connectors, still no tachometer ???
Need help.
Cheers
Need help.
Cheers
speed sensor MPH and engine RPM sensor are different parts in different places,
MPH in the rear side of the trans.
RPM in the aft edge of the engine block under the air cleaner
What was the last thing you fixed??
None. The RPM just quit.
I did look at the cluster - clean it .
Then I checked the RPM sensor - under the air box - Looks good with good ohm reading (around 1K ohm)
Car runs OK - there is some hesitation at 3/4 or full throttle once in a while. Need to check the distributor caps and rotors.
check the throttle position switch through the brain wires it might not be giving the WOT signal,
for the Tach Also check the CE panel for a possibly disconnected wire you will need the WSM to figure out the correct wires to test
