928 Forum 1978-1995
Sponsored by: 928 Specialists
tachometer stopped working ???
Old 10-05-2008, 09:09 AM
oups59
oups59's Avatar
Originally Posted by ttaddict
did you just buy this car on ebay within the last few weeks.
Yes
Old 10-05-2008, 06:20 PM
oups59
oups59's Avatar
Still trying to find why the tachometer is not working
This morning I swap the instrument cluster with the one in my '87. Still no RPM. I put the one from the '88 into the '87, RPM OK. So it is not the instrument cluster - witch is a good news
Is it possible to use a spanner to detect if the engine speed pulse into the ECU is OK ?
Old 10-05-2008, 11:37 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,548 Likes on 1,430 Posts
if the engine is running then the crank position sensor is good, you should check the CE panel for the correct connections, get a fuse relay chart here www.928gt.com
Old 10-06-2008, 08:52 AM
oups59
oups59's Avatar
Mrmerlin,
I checked the CE yesterday (for the second time), swapping fuses and relays. Still the same, no Tachometer.
I found in another thread the color of the wire for the RPM feed. I will take a look at it tonight.
Old 10-07-2008, 01:38 PM
oups59
oups59's Avatar
I trying to locate the tach lead wire on my '88 S4. Do anyone know what is the color code for that wire?
From a previous thread, it is supposed to be white/blue.
Anyone can confirm?
Old 10-08-2008, 03:25 PM
oups59
oups59's Avatar
IT IS REPAIRED
A wire was cut behind the CE between connector W and J.
Old 10-08-2008, 04:11 PM
the flyin' scotsman
the flyin' scotsman's Avatar
excellent Luc...........did you see why the wire was cut?
Old 10-08-2008, 04:20 PM
oups59
oups59's Avatar
Probably by the PO . It was a very clean cut. But I have no idea why.
Quick Reply: tachometer stopped working ???
