New wheels + tires installed (UPDATE II: THEY FIT!)
Supercharged
You only need about 1mm of clearance. The wheel had better not flex .
If it were my car, I'd probably tap the hard line with a hammer ever so slightly, then inspect for wear from time to time. That's probably a bad thing to do, but...
Alternatively, you could grind the backside of the wheel to get it to fit.
Or get the 3mm spacer - wheelenhancement carries them. Call them.
Hammer is the last option. I'd hate to get even a small kink in that line.
The smallest spacer Wheel Enhancement sells is 4mm. And I ordered them yesterday.
And... I'm no metalurgist... do wheels actually flex? Never had to think about it.
IMHO it is not worth risking your life, others lives and your sharks future for a set of wheels.
IIRC doesn't Wayne have the same wheels on his shark? I can't remember what diameter he is running but they look sharp!
But does he have big reds....
Only the manufacturer can confidently provide the answer if the wheels will flex or not. All metals will yeild at some point, the amount depends on the alloy used and if it was treated in any way.
These wheels would definitely fit a non-big red 928. And they may be available to someone with such a vehicle in the very near future if this doesn't work out for me.
More than anyone wants to know but...
All materials have a Modulus of Elasticity - the linear relationship - in the elastic range where we hope to operate - between stress (load per unit area) and strain (change in length per unit length), so any load placed on a material will cause it to change shape based on its Modulus of Elasticity. Steel is 29,000,000psi/(in/in).
Bottom line - everything "flexes" under load - changes length and shape ever so slightly. icon107:
Rod
Rod
Rod
Rod
Rod
