Shift centering spring busted? Help needed for 5 speed
Craic Head
OK, I see the input bearing on page 34-15 of the manual, as part of the input shaft assy.
Here's one of the diagrams from the WSM
(I added some labels to help me navigate and cleaned up the WSM pic. Please correct me if I got anything wrong)
![](http://forums.rennlist.com/upload/transmissiong28.10annotated2.jpg)
In addition to the input bearing described by Wally and Jim, are #42 and #46 the only ones that would most likely 'need' to be replaced? (I see that there are other sets of needle bearings and tapered roller bearings as part of the different shafts, but I just want to fix what's broken or relatively easy for a noob like me to replace). I'm thinking of #42(x2) and #46 (x2) and the return spring and reverse lockout spring plus possibly input bearing.
Also,
Can I assume that all of the items marked 'gasket' (5) or 'seal' in this diagram (17, 19, 34, 49) or O-ring (31, 35) would be included in the seal kit?
Also,
Basic Sponsor
Jim & Wally,
You raise a very interesting question why the big difference between the different input bearing prices.
928 302 152 06 = $477.92
928 302 152 10 = $53.02
928 302 152 00 = $274.94
There are 14 of the -10 in Germany so available.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
That WSM picture is for early box. I can be confusing when you try to fix '85 MY version as so many things have changed. I think its better to use correct PET picture and just try to understand what pages in WSM are valid in you case. But your idea is fine. I would change both #42's and #46's.
Forget my earlier advice to change selector shaft support bearings. They were introduced in '87 MY and thus doesn't exist in you case. This is one more thing which is both good and bad in later MY boxes. They probably make selector more easy to use but at same time introduce yet another part to go wrong when gearbox is worn.
