928 Forum 1978-1995
Sponsored by: 928 Specialists
I went over to the Dark Side....
Old 09-06-2008, 10:57 PM
  #46
BC
BC's Avatar
Ah. Okay.
I just looked, however, at the valve sizes. The Blue open chamber heads have 2.06 or so from my calipers, and the orange heads seem to be like 2.25.
The exhaust valves also look bigger.
Old 09-06-2008, 11:05 PM
  #47
BC
BC's Avatar
I was shooting for about 10.5 or so for the compression. If I can figure out what the hell the fuel tank is made from (steel or plastic) I may run ethanol in the truck, and will then go higher, like 11 or 12. Or I may leave it 10.5 but try and find some turbo headers (!)
Old 09-06-2008, 11:18 PM
  #48
James-man
James-man's Avatar
Originally Posted by 928andRC51
His next ride should be a tow truck with the hood welded shut so it will not get disassembled!!!
J/K
Now that's funny!
Old 09-06-2008, 11:33 PM
  #49
BC
BC's Avatar
Anyone have a comment on why the closed chamber heads have a 2.25 intake valve?
Old 09-06-2008, 11:46 PM
  #50
largecar379
largecar379's Avatar
not that my opinion has steered you away from doing this swap....but---
have you thought about the smog inspection issues with what you're doing...?
Tahoe's did not come with big blocks in them of any flavor, so I'm curious as to how you'll pass this off to the smog cops......?
You know the score about blowers and such, remove and re-install after inspections, so I my thinking is, it's going to be an interesting scenario when the cops say, "Hey, this don't belong in here...."
Comments?
--Russ
Old 09-06-2008, 11:48 PM
  #51
BC
BC's Avatar
Good point. Its not registered in CA. Nor would it even pass any inspection now. So thats no issue.
Comments?
--Russ
Old 09-06-2008, 11:56 PM
  #52
FBIII
FBIII's Avatar
It looks like a previous owner put the big valves in an oval port head. The same thing recommended for the open chamber heads. If the guides and valves are good use them and look for some dished pistons. If you don't want to go that route and the valves are good, use them in the blue heads. You just saved a couple hundred dollars.
Old 09-07-2008, 02:11 PM
  #53
BC
BC's Avatar
Cams are 100 bucks or less. Wow. And I only need one!
I will be towing, but I don't want an anemic motor over 3500. So I was thinking of one that has about 1500-6000 for a power range listed?
Old 09-07-2008, 03:01 PM
  #54
Landseer
Landseer's Avatar
Brendan,
Are you sure the rotating parts are good for >4800?
Old 09-07-2008, 03:43 PM
  #55
BC
BC's Avatar
Originally Posted by Landseer
Brendan,
No. I was thinking I would be okay for up to 6k even with a cast crank if I were to try and save some money.
It is indeed a truck, so it may not need the 6k redline. But it sure would be cool.
Robust steel rods, forged pistons, and some roller rockers and roller tappets - seems like it would be okay.
Old 09-07-2008, 06:10 PM
  #56
BC
BC's Avatar
New info - the Orange heads with the big valves have WAY bigger intake ports. As in two fingers fit through but on the blue heads they don't.
Old 09-07-2008, 07:45 PM
  #57
BC
BC's Avatar
Like 1.8 or so compared with the smaller port heads being 1.4
Old 09-07-2008, 08:52 PM
  #58
FBIII
FBIII's Avatar
I think someone did the big valve gasket match upgrade to the closed chamber early heads. The same upgrade that needs to be done to the open chamber heads.
Old 09-07-2008, 10:22 PM
  #59
BC
BC's Avatar
Thats alot of material removed.
Old 09-08-2008, 02:01 PM
  #60
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
How you gonna smog this thing Brendan? How's that for a bucket of ice water on your party?
Quick Reply: I went over to the Dark Side....
