Shock bolt stuck!
Update: I took the whole assembly to a auto repair shop to press it out and they could not do it. I proceeded to a machine shop with a HUGH hydraulic press and it would not budge. The M/S is going to cut out or burn out the bolt what a pain.
Team Owner
I call it the lower rear shock link pin, I wonder if this car got into some salt water thus the pin corroded in place. Ther is a hole in the bottom of the hub carrier and you see the pin and possibly spray PB on it if things are corroded
