wiring gremlin
Hello gentlemen, I need some help please. Just bought an 84 928s,5spd. Has some bugs. My tach, speedo , gas gauge, oil pres gauge are out. I hope it is all related to a single problem like relay , ground wire ,fuse etc. Air comes on for 5-10 secs and then cuts out. I suspect low freon. Will have it converted to R12 tommorow. Any advice will be greatly appreciated. Thank you .
Supercharged
Have you checked your fuses? In particular Fuse #12. https://www.928gt.com/t-8384fuse.aspx
Could also be a bad ground or even the printed circuit on the back which I believe is NLA.
AC is likely low freon. If you need a write up to track this down, read this... https://www.928gt.com/t-wallyhvac.aspx
All courtesy of 928 Specialists!
