stop screw on ISV question
Looking at the internals of the ISV I just took out of my car I see the piece that actually opens and closes is just barely wide enough to seal the air flow. It has a curved face and appears to rotate to open and close.
Mine is sitting with a very small gap open and there appears to be a screw (small allen) that would function as a stop screw, possibly to adjust the gap or eliminate it.
Is this normal or should it be filling the opening completely?
Also, I put 9 volts to it and it doesn't move, I thought I read somewhere it could be tested with a 9 volt battery.
I've got a new ISV coming to me but I'd like to know if the one I'm looking at right now was set up correctly and if the 9 volt test should have caused it to move.
Thanks!
Thanks!
Thanks!
Thanks!
I did check the older style on the 82 with a 9 volt battery and it opened. I didn't try the 9 volt on the later model.
Rod
