How to identify jetronic??
L-JET will have this (Air Flow Meter) under the air filter housing:
LH will have this (Mass Air Sensor) under air filter housing:
Thanks 928 Intl for the pics!
I have under the airfilter, located something that only resembles the CIS. That means the K-jetronic, right. Ok, so next up...how the f.... do i know if its a 4,5L or the 4,7L....
On the oilpan it says : 101.201.9R30 2786.080/02 if that helps any....and as said before, it says ATR where you guys have numbers ID...
The car is currently in the process of getting a new gearbox fitted at Toyparts tuning.
First, look at the top front of the engine to find the M28/XX number stamped into the flat surface on the top of the block.
After you find that, go to www.928gt.com then 928 Tips/Links, then Tech/Specs, then Engine Types.
Measure the outside diameter of the alloy intake runners .....my guess is possibly the block was bored to a 4.7 .... 97 mm S piston BUT odds are the rest of the engine cams ,valves ,heads, intake is still original 4.5 none S .
Hear hear- This is what Ive been told. Now what does that mean?lol......which engine do I have, and what superchargerkit would be appropriate for this engine..,.this is why its important to figure out. SORRY GUYS FOR THE CONSTANT NAGGING AND ASKING, AND BAD ENGLISH:-)
Here is a pic of whats under the aitfilterbox.
But I was told this engine is replaced mid-90`s, so it is not the same that was in the 78.
