Throttle linkage popped off
So I'm driving along when the gas pedal drops to the floor. In a panic, I grab the key and turn off the ignition when I realize that the throttle wasn't stuck all the way down, but instead the linkage broke.
It turns out that the ball on the end of the rod that connects to the throttle body had popped off.
I put the rod back in place but I don't see anything that would cause it to not pop off again. My question is, what holds this rod in place?
Thanks,
Thanks,
Without the pin, you can take a pair of pliers or flathead screwdriver and pinch the circlip inside the cup that snaps over the ball when the cup and ball are mated. That will at least give you a tighter connection.
Matt
