Seat connector help needed.
My 12 way seats are currently 3 way....... removed the seats and found the following:
1 - connector broke and ends taped up - disconnected when found, another PO special.
2 - connected - I assume this is the main motor control?
3 - just sort of sat there doing nothing, should it have a connection?
4 - As found connected to nothing, but has the remains of female connector still attached.
6 - (not sure what happened to 5?) nothing connected to this.
Last pic - this fell out from near the front - does it stop the plastic guard from touching the motor?
What connects to what? I want to get everything reconnected before I strip the switches.
Basic Sponsor
1) goes to either 3 or 4. Do you have heat in the seats. If not one of the connectors could be for that.
2) main power feed from the floor connector
3) see 1)
4) needs connector 1 me thinks.
6) Memory module maybe
?) Clips arond the emergency cables at the front of the seat
3) see 1)
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I've just noticed that connector 4 goes to my seat belt? Any ideas as i can't find on wiring diagram.....seat belt not fastened chime?
I know this thread is a bit stale, but I am having the same pangs of curiosity after removing my 8 way seats.
In my car, but using Bert's excellent pictures:
1 does got to 4, but the WSM seems to indicate that these pins are duplicated on Terminal 30 and 31 of the bigger plug, which goes to #2 in Bert's pics ( See page 72-13 in the WSM, as I may be reading this wrong.)
So, that still leaves connectors 6 and 3. These are also connected to nothing in my 8 way seats, and everything still seems to function. So, what do they do?
-Ken
-Ken
I just had my seats out recently and am trying to remember. I believe that the extra connections are for seat heat or lumbar support. The seat harness is pre-wired for these items whether you have those options or not, so they may not need to be connected. Maybe someone else will chime in if I am wrong...
Matt,
That would make sense, probably cheaper/less complex to just make one harness. Anybody out there with heated seats or lumbar that can confirm if these are connected in your seats?
-Ken
-Ken
