928 Forum 1978-1995
Sponsored by: 928 Specialists
How to bench test PSD unit?
Old Jul 17, 2008 | 04:26 PM
Maybach_Man's Avatar
Maybach_Man
ryan:
if you have the unit out of the car... there is only two allen bolts holding the pump to the unit.... easy to unscrew and test as a seperate unit... be careful as my wirig colours did not match the diagram
regards
geoff
Old Jul 17, 2008 | 04:29 PM
RyanPerrella's Avatar
RyanPerrella
Originally Posted by Maybach_Man
ryan:
regards
geoff
Good to know. I actually havent looked at it closely but will give it a shot. I should then be able to just put power to it and see if it works or not
Old Jul 17, 2008 | 04:53 PM
steaditim's Avatar
steaditim
Ryan:
When I tested my unit, the pump would run but it just wouldn't build any pressure. I checked that all the lines were clear but it still would not build pressure. I gave up and had it rebuilt.
T
Old Jul 17, 2008 | 05:07 PM
RyanPerrella
i recall this pump running before but wouldnt build pressure. But could that not be a problem with something other then the electric motor or pump itself?
I will hold off until i put power to the thing and then see where i stand
Old Jul 17, 2008 | 07:38 PM
john gill's Avatar
john gill
pump not building pressure is symptomatic of pump failure , these units are built to such close tolerance that there is little that can be done to rebuild them , good luck on the rebuilt units , the original manufacturer (ATE I think) in Germany would need to specify the toleraences for any reliability , thoroughly reseached this path before buying a new unit unit from Porsche here in Australia 2 years ago , however the unit cost $3K so at that price a rebuilt one with for warranty for $1k is certainly worth a look .
