928 Forum 1978-1995
Sponsored by: 928 Specialists
Instrumentation POD Ground??
Old Jul 16, 2008 | 09:36 PM
Skiviking's Avatar
Skiviking
Default Instrumentation POD Ground??
Just curious, I was wondering exactly where are the ground points on the pod? When I removed the pod I looked for them But only found the 3 Wiring harness that plugs into the flex circuitboard and of course the wiring that go to the switches on pod. Thanks for any idea or help here...
Old Jul 17, 2008 | 12:55 AM
JG928S4's Avatar
JG928S4
look up old post "slapping the Pod", I had an issue like that in the past.
Old Jul 17, 2008 | 10:26 AM
85fortheDrive's Avatar
85fortheDrive
Artist Formerly Known As 84totheFloor
I have had the pod out many times, but can't recall a grounding point on it. There is, of course, a grounding point below the pod in the driver's footwell.
Old Jul 17, 2008 | 10:32 AM
Skiviking's Avatar
Skiviking
Thanks for the tips Guys!! I'll check them out!
Old Jul 17, 2008 | 10:48 AM
Tom in Austin's Avatar
Tom in Austin
There are about five or six grounds among the wires going to the pod connectors. IIRC, these ground everything within the pod and no other grounding was used.
Old Jul 17, 2008 | 12:26 PM
Skiviking's Avatar
Skiviking
MANY THANKS Tom!!! That was the answer I was hoping for.
Old Jul 17, 2008 | 08:40 PM
WICruiser's Avatar
WICruiser
There is a bolt into the steering column support below the pod that has several (4 or 5 I think) ground wires attached - at least thats what I found on my '85.
