remember when the wheels compress in the rear they pivot slightly inwards so rolling the fenders and adding some wider spacers might be the trick, otherwise you could fit a slightly narrower tire
The S4 is going to the next door neighbor actually. The rear tires are only 8 months old, but the knuckle head that put them on didnt much care about the fitment. So i am paying for it now. I have 1 new 285 on order to match the passenger side which is still like new. I just want to fix the issues that i am finding with the car and move on. But i want to make sure everything is correct and as it should be. According to my own experience a 51mm offset in the rear with an 11" wide wheel is ideal. The wheels are 45mm so i just at a 5mm spacer to get it to 50 and i should be good.
I am hoping to find 5mm spacers for less then $62, but worst case scenario i just buy the ones on the Ebay ad and call it a day.
So i am still looking for some good used 5mm spacers.
