Mystery Part
Regarding 87S4 auto US model. In completing the coolant expansion tank RR, I had to remove the airbox. In refitting parts that were fastened to the airbox, this part just broke away in my hands with little force. It formerly attached to the passenger (right US) corner of the airbox and has a rubber cap pinch bolted to the end. The end of the hollow aluminum tube is now dangling. Please advise and have a great 928 weekend.
Uh, there's a problem. I can't find the other end now. Do you know where it comes out? Does anyone have a photograph? This is really starting to bug me that I can't find it. I specifically recall it dangling, or at least I thought I did, and now I can't find it either from topside or underneath with the car up on stands. Any guesses as to where this thing comes out?
Cheers, Jim
Thanks for posting this. Very interesting a lug nut will fit there. I'm partial to the ball bearing solution and have used it on the passenger side. Found that the driver side is punctured and have removed it. The hardware store closed before I could go back and get another ball bearing. Will be back in tomorrow morning. Thanks again. You know, if not for this forum and you guys, I would have been breathing more CO and I did get a serious head ache on a short trip a couple months ago. Thanks a bunch to you guys for pointing this out. FWIW, I did search the archives for "CO sample tube" but, of course, that was to precise and needed to be broadened a bit. Again, thanks.
Received 1,624 Likes
You can also use a $2 NPT cap nut, available at your local hardware store, to cap the bungs in the manifolds. This is what Porsche did starting in mid-89 except that the Official Porsche cap nuts cost $36 each.
Also, you'll need to plug the holes in the airbox.
