928 Forum 1978-1995
Sponsored by: 928 Specialists
power antenna wire color
Old Jul 12, 2008 | 11:43 AM
funkyboogalooo's Avatar
funkyboogalooo
Default power antenna wire color
hi all
I need a quick answer as I am at this precise time fitting a new Becker CD to my 1984 S2. I have managed to locate and understand all wires except 1. What colour is the power wire for the electric antenna? Anyone know?
Cheers
Mike
Old Jul 12, 2008 | 11:48 AM
M. Requin's Avatar
M. Requin
On an 86.5 it's white. Located beneath the console. Hope this helps!
Old Jul 12, 2008 | 11:54 AM
funkyboogalooo
That was my guess, the white one. Very much appreciatte the confirmation
thanks
Mike
Old Jul 12, 2008 | 01:32 PM
M. Requin's Avatar
M. Requin
Hmm, while running an errand it did occur to me that I should have noted that the white powers the built in antenna pre-amp. If you're talking about a power-operated antenna mast, that's a different story (I don't think you are, because of the MY, but thought I would mention it just in case).
Old Jul 12, 2008 | 02:03 PM
Brett928S2's Avatar
Brett928S2
Hi
Ummm 928s in the Uk don't have power aerials....not as standard anyway....
All the best Brett
Old Jul 12, 2008 | 04:23 PM
M. Requin's Avatar
M. Requin
Hi Brett - how's the project? We haven't seen an update in a while. I added my 2nd comment because I know there are aftermarket antennae ("aerials" to you, old son) on a few 928's over here. And did not early OB's have them? That's a Q, not a statement...
Cheers,
Old Jul 13, 2008 | 01:04 PM
funkyboogalooo
Hi Brett
Well mine does
Mike
Old Jul 13, 2008 | 01:12 PM
Brett928S2's Avatar
Brett928S2
Cheers,
Hi Martin
Still working on the car...lots more electrics to sort out through a Mosfet , once I discovered that running 8 relays wouldn't work properly with my 8 Pulsoids at 17 amps a time lol..
The Mosfet will run 200 amps continuous and 300 for shorter periods
Also had the hatch and rear quarters Limo tinted (95%) to stop my twin 15lb bottles overheating and overpressurising...that worked
Thinking about doing some more dyno work at the moment , although my local dyno will only go up to 1000 hp, then it flashes red and all shuts down , so I am told But might be fun to try lolllll...
All the best Brett
Old Jul 13, 2008 | 01:15 PM
Brett928S2's Avatar
Brett928S2
Originally Posted by funkyboogalooo
Hi Brett
Well mine does
Mike
Hi Mike
Most 928s have the aerial in the front screen....I think "some" had a standard aerial if no screen aerial...
I have never seen a "standard" power aerial, although I stand to be corrected ?
All the best Brett
Old Jul 13, 2008 | 02:41 PM
funkyboogalooo
Brett
You going to Castle Combe in September? If so you can check it out.
Cheers
Mike
Old Jul 13, 2008 | 03:42 PM
Brett928S2's Avatar
Brett928S2
Brett
Cheers
Mike
Hi Mike
I may be coming for the social chat but doubt I will run there, Nitrous doesn't like corners lol
All the best Brett
