Fuel Tank Imploding
As you know, the car has been running a dry sump for about 2 weeks. Have not had any time to play around with the crank case and vacuum hoses, thus I left it alone.
The car seems to run ok, but there is something wrong with the fuel tank breathing as it implodes and the engine dies after spirited driving. When I release the fuel cap I can hear hissing as air enters the tank.
Do you think it is possible that I am sucking too much air out of the tank via the charcoal canister, which vents into the intake, which in turn is being robbed of air via the dry sump installation. Or am I missing something?
Any pointers would be gladly appreciated!
Thanks in advance,
Alex
Thanks in advance,
Alex
Administrator - "Tyson"
I had the same problem when my gas tank vent system was clogged.
jim, i thought there was the provision for fumes to vent via the charcoal canister back into the intake? looking at porkens thread a few lines down from here i keep reading it that way. as for alexs problem - you would imagine the drysump install and this new problem are related as the tank has only just started doing this, but maybe not?
Owns the Streets
Needs Camber
Needs Camber
Alex, if you have copied the PACE system, then remember it was designed for an oil catch tank system rather than the stock inlet & breather - so either replicate that or redesign with one-way valves (which is the way I will go). However sounds more like a blocked breather hose somewher.
A
A
A
A
I have a feeling that I might have squashed the breather hose when I dropped the rear subframe to install the new GTS gearbox... Will have to look into it when I get the car back from Promax...
