Printed Circuit Board Question
Specifically for the instrument pod. I tried to search on the topic, but didn't find to much info. Especially for an '83. Be advised, my electronic inexpierience/ignorance is quite high. My questions are;
1) Is there a way to test it? I assume you can only check for continuity, but continuity to what (and where)? Are you going directly off the wiring diagrams in the WSM's?
2) Say you find a bad circuit. Is the whole thing shot, is it repairable?
3) I hear a lot of people say replacing it can solve alot of problems. PCB's for the OB's are no longer available. How would one go about replacing it? I would have to assume a used one would be a 50/50 shot of working better than the one you have.
4) Is it really worth messing with at all?
I'm not having huge issues right now, just some annoying glitches. However I am getting ready to R&R the pod, and was curious what to look for and expect. Thanks in advance for any information/opinions on the matter.
Dwayne just did a great write up on this. I bought a NOS foil, and everything works perfectly now, except my SPEEDO.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
If this write up isn't in the DIY's, it should be. Dwayne does good work.
Go here for all of Dwayne's great work. Thanks to Bill for putting together and Dwayne for all of the info.
http://www.dwaynesgarage.norcal928.org/
