Papa's got a brand new bung (X-pipe install)
Rob, if those are GT resonators I'm seeing, and you have a rear-muffler bypass pipe, it's going to be sex to your ears. But until then, you have to wait until you get home from work.
Archive Gatekeeper
Just got in from the first drive. Holy crap, what a sound! The butt-dyno says it pulls significantly more strongly from 3500+ up to 6000 or so (in 3rd gear...) I ran out of room to mess around some more but this mod really transforms the car. There's no drone at any rpm, just a good bit more burble that is largely shut out by putting the windows up. But it is loud above 4000 or so! (X-pipe + GT resonators + GT muffler.) 2 thumbs up!
This Impression is Worthless Without Dyno Curves, but there's clearly an improvement. I should probably baseline dyno the car now with Greg now, just to see where it's at.
D'oh! Here I am all cool on the internets, busting out the dremel on a heat shield that I've mounted upside down now at least three times. What a dork I am....
the narrow part of the clutch heat shield goes to the front of the car and you shouldn't have had to do any surgery
I recently installed the same X pipe on my GTS (sourced from Roger) and it went on very easily. Only downside for me was that it spat out one of the fibreglass tapes towards the end of the first track day. I will be getting some custome pipe sections to mate between X pipe and cat back system to remove the need for the tape. Apart from that, I only had to modify the belly pan support bracket to clear the back of oxygen sensor. I also removed the airpump and associated bracketry and belts. End result is a great sound, slight increase in throttle response at higher revs and *brilliant* access to the TT clamp & flexplate. Charles 93GTS & 87 5 Speed in OZ
I don't see why it wouldn't fit OBs, I had an OTT design on my '83 with the factory manifolds. Or, if you need/want to stick with the single pipe cat-back, Motorsport offers a Y version, IIRC.
The strap clamps can be found in a stepped configuration now, surprised that it appears the ones supplied are one diameter.
Chronic Tool Dropper
X-pipe is fine for earlier cars as it is, except for the annoying part where you only have one pipe to the back and two outlets from the X. Next available consonant is Y, which coincidentally has the correct number of places to whch you can attache the plumbing parts.
Archive Gatekeeper
Jeff-
Just boxed your X-pipe up, I included the 2 pairs of easyseal clamps that connect the X to the cats and the cats to the resonator pipes. The only thing you'll need is some of the fiberglass wrap and a new set of M8 bolts and nuts for the downpipes. And of course it occurs to me that I forgot to put the test/bypass pipes in the box. Will mail those separately. Headed to Fedex now, will PM you later.
Super clean under there! LOVE IT! I need a life for that very reason...then I could REALLY get my car clean!
Thanks for sharing... Seems a bit pricey to me, but it sure does look good. I wonder if I could pass TX emissions w/o the cats?? Thinking about my '88 S4 and my '92 GTS...
James
James
Dont get me wrong Rob, they are a nice looking set of pipes.
I still think I may get some
I had my H pipe made at the local muffler shop so that I didn't have to run cats
(Sports car = full power - no emissions)
I also had the Y at less of a angle so that the entire bell housing is accessible
Total = $300
I agree James that $420 is a lot for a x pipe.
Total = $300
Total = $300
Not all x's are equal either - the distance to the X from the engine, angle of entry and exits, pipe size etc. all matter. So for those considering it, the welding up an ebay X onto some pipes to fit your 928 won't net you the same gains.
