Pretty sure the park fuse has blown...but it's easier to delete the system than find a 1-amp ATC fuse
Ken,
I ended up buying a pack of 100 1A fuses, I have 99 left. If anyone needs one for their hatch lift, PM an address and I will send one in the mail.*
*Offer good for the first 98 requests ONLY! I need to keep one in reserve.
First time noticing that each side has a different switch retaining 'nut'. The right side 01 has a taller spacer. 928.613.431.00/01
Recommend removing each side housing and removing the switches off the car. The ***** have thread locker applied and could use some heat (soldering iron?) and/or PB blaster as Stan mentioned above. Note, if the motor is removed the unlocking pull lever has to be zip tied in the up position or the hatch will not close.
