dual disk clutch install help
For the shims, I used 10AWG copper wire (lose the insulation and bend it in a U-shape) then use the c-clamp technique Jim described, slide them in under the T-shaped thingys, release clamp. Then when you bolt it to the flywheel it will compress and the shims will fall out.
Cheers, Jim
Don't move the transmission, it's just a big waste of time. Shim the PP like others have said and it will go in easy. You could even use the right size nailgun nails as shims.
Dan
'91 928GT S/C
Dan
'91 928GT S/C
