S4 Injectors
Basic Sponsor
Hi Beach,
Google Summitt Racing for the injectors and email me for the seals.
Roger@928sRus.com.
Welcome to the board - Brits rule.
Roger@928sRus.com.
thanks for that, ok i found the ones FUSE69 is looking at and i take it there ok for mine? and the correct seals can be had from your good self, i take it this is a worth while thing to change as mine are 19years old ?
Basic Sponsor
Hi Beach,
Before you jump tell us about your car. 1987 S4?
Someone can then best advise on which injectors to use just to be safe.
Roger
Roger
ok my car, its 1989 gt with 88000 miles in black. i am at present replacing all high tension engine electrics and then will do the fuel side of things. i have a bit of jerking when travelling at low revs so trying to get rid of that problem. i have had some general electric faults that i have now sorted that seem the norm for these, and thanks to a good read of this forum for the last 2 weeks have now sorted.
The newer 4 pintle injectors did seem to give my 928 a slight HP boost...or at least it feels that way...however DO NOT install the injectors with the supplied lower O rings....(ask how I know)...as a 928 does not run well with 8 vac leaks.... Just order them from roger.....the correct ones I ended up with were about 16.5mm or .65 inch
https://rennlist.com/forums/showthre...ight=injectors
Just as follow up / reference for others...
The 19# Ford Motorsports injectors M-9593-C302 are NOT 4 hole pintle injectors...
Just so you know...
Mine arrived today from Summit, so it was the first thing I checked, but alas they are single hole, needle style injectors...
No doubt they will still be a vast improvement over my 20yr old Bosch units...
//Ben
Just so you know...
//Ben
FWIW, I think that the Bosch PN for the 19 lb "design III" four-hole injectors is 0280155710. I am not sure what the Ford part number is for this exact part, but I don't think that it is 9593C302. There are some other Bosch yellow top 19 lb injectors listed with different part numbers, but I don't know what the differences might be.
Five0 Motor Sports has them on their website: http://www.fiveomotorsport.com/Injector_SetsFORD.asp
I just bought a set of four-hole 30 lb injectors (Ford Racing M-9593-BB302/Bosch 0280155759). These have a one piece all plastic body that is more narrow than the earlier parts. Hopefully I will get around to installing them soon.
HTH, Bob
HTH, Bob
Iceman/RET - If I have correctly interpreted your information, there are two different types of injectors on the Five0 Motor Sports website(http://www.fiveomotorsport.com/Injector_SetsFORD.asp) :
1st set are the single hole, listed as '19lbs/hr Yellow Top' @ $305.50
2nd set are the 4 hole, listed as 'Use the Design III in place of our Yellow Top Upgrade - Bosch p/n 0280155710-F6VE' @ $339.50
Iceman/RET can you confirm?
I'll find out in due course, but I suspect it's hard to put an absolute value on it as there are a number of other contributing factors such as MY and other performance mods. I think it's resonable to say that replacing the injectors is a PM job, that we can update to a newer, more efficient design is a bonus.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I know my injectors need some loving... but if these things are a direct drop in, I know where my stimulus check is going. I also am a little worried about gas mileage though after this install.
Righto - I've just spoken to FiveO and they have confirmed that the injectors described as '19lb/hour Yellow Top' and '1987-91 Porsche 928, Cross Referenced, Direct Replacement', both priced at $305.50 are a) the same injector with different coloured bodies and b) both the four hole design. The Design III are a newer, slightly more efficient design, but they wouldn't comment as to 928compatibility. The ones from Summit are the single hole design.
I'm going to go ahead and purchase the the 4 hole Yellow Tops from FiveO and will let you know what turns up - as they will be shipped to the UK it will be a week or so....
Location: Seattle - it's not Hell, but you can see it from here!
the Design III's work great in a 928. i've had them in 2 or 3 years now.
they do have to be modified slightly to fit.
