WTB GT wheels
WTB GT wheels
Guys I am looking potentially for a front set only (depending on the price I am happy to reco them) of the 89 GT fronts, these are the anodized 8" wide and 60 mm offset wheels, if anybody has some, maybe you have a damaged set or know of even one please let me know.
Thanks Greg
Thanks Greg
I have a set of turbo 951 wheels and these are only different on the front by 1". The only reason I would like the 8" is so that I can run a 245 tyre on the front and rear. They are selling Hankook R spec tyres here for $600 a set in the 245/45/16 size and that is the only option, if I had an 8" rim great, if not I will run a Toyo tyre and that has the options of different sizes, just double the price.
Greg
Greg
Greg
Greg
Alex
Alex I will pass on the 9"s on the front but tell me about your big yellows and have you got your dry sumped engine together? Sorry if you have posted about this before but I rarely get to look at the list. We have a dyno day this Saturday with the Porsche club so that will give everyone a good comparision against other 928s and other P cars.
Greg
Greg
Greg
Greg
- The Big Reds are perfectly adequate for endurance racing at the Ring, which in itself is reasonably gentle on brakes.
- The hassle of sourcing rotor hats and discs from Alcon is huge.
The drysump is on the car, but my mechanic has got a bad back, so he has not been able to connect the hoses back to the tank. I am exasperated, but there is hardly anything I can do, given that he is a "one-man-band" and the car is on the ramps.
Rest assured, I will be the first one to brag about it once the engine is running and the car is pulling 1.5gs in corners on Toyo 888s without the slightest drop in oil pressure...
Alex, I know the feeling of a one man band, me being that band and being cash strapped. I know my second car won't be as fast as your GT but being an auto it will be hard on brakes I feel. The early car does has better brake duct cooling in its favour and I think but I am not sure but having the slots in the wheels allows for the air to flow through from the brake ducting. The brake ducting really works, the reason I make that comment was we drove through a plague of locusts and they were plastered all over the inner parts of the wheels.
You say you have GTS running gear? I thought you were working over your GT engine? You had your heads done etc, we have a guy here that has done the same and is doing some tuning with the Sharktuner and getting some really good results.
What type of power are you hoping to get from your engine? RWHP please some guys (dyno operaters) in the UK seem to want to quote crank figures. The guys doing the heads (2V)for my 5.35 litre engine or 327 CI, that was a great Chev engine hopefully for Porsche too We have estimated from data and programs and from what my 5.0 litre makes so far with minimal tuning around 350 rwhp through an Auto on a Dyno dynamics dyno, hope to have that engine together in the next few months, just running the teflon crank scrapers and thinking about a thicker sump gasket, anybody care to share any info on that area?
Going back to the brakes are you running aftermarket discs? I was thinking about the cross drilled ones with Pagid pads if I can get them, thiis car which is my new wife's car will also inherit my Ledas, good for weight savings, I think I can get this 85 model down to 1500 kgs dry, which isn't too bad, I do and complete this process have by changing the suspension,-20 kgs battery box and battery,-5 kgs, alloy spare wheel from the 951, 3 kgs new exhaust 12 kgs. Might cut some weight out of the bar reos too. I don't think changing to 4 piston Brembos will save any weight, however you may find it interesting to find out that my F50s weight about the same as the original steel calipers and discs.
So we can't wait to see how this one goesAlmost as much as you want to see how yours goes, are you Sharktuning too? My wife btw is bit a leadfoot compared to me We are hoping it might be able to get to 300 kph, she can do that run
Cheers Greg
Cheers Greg
Hoping for around 420bhp at the crank - whatever that is at the wheels...
