928 Forum 1978-1995
Sponsored by: 928 Specialists
5 Speed Engine R&R
Old May 15, 2008 | 10:58 AM
pjmcgnns01's Avatar
pjmcgnns01
Default 5 Speed Engine R&R
I need to R&R my motor for the second time in 12 months. Last time I removed the clutch pressure plate as part of the process.
Does anyone know if you can remove the engine with the clutch plate attached?
Sure would save a lot of headache!!
Old May 15, 2008 | 12:23 PM
karl ruiter's Avatar
karl ruiter
I think you can, but that you may need to remove the radiator, and put a plywood plate in front the the ac condenser as shown (I think) in the WSM. The hard part is getting the motor far enough forward that the stub shaft will clear the bell housing.
Old May 15, 2008 | 12:28 PM
SteveG's Avatar
SteveG
Year??
