Oil pressure sender wiring GTS
Hi Guys, I have missplaced the wiring diagram for my 93 GTS. Can anyone tell me which coloured wires go to which pins on the OP sender. Wire colours are Green with Black Stripe, Green with White Stripe and Brown with Red Stripe. Pins are marked WK, M and G.
I have just changed the oil pan gasket and can't get any oil pressure up spinning the engine up on the starter and want to double check the wiring before I go out and buy a mechanical oil pressure gauge. Thanks in advance, Charles - massisvely stressed out!!!!
