Engine installed - no start
Supercharged
The only other thing (besides cam timing) that I can think of is the firing order. Do you have your plug wires going to the right places? I accidentally reversed two wires on mine after the re-build. It ran, but didn't want to start easily.
The cylinders need to dry out as well. After you try again for a while, pull a plug and see if it is wet again. Did the injectors come with the new engine?
I ventured in the garage today, the plan being to check the timing.
Turned the engine to TDC by hand:
Something odd was showing from the passenger breather hole, so I removed the cover and found this:
At this point I called it a day and retired home to appreciate the finer points of cold beer.
Well, obviously the belt is BAD. The timing is WAY off. You appear to be on TDC for cyl number 6. So, the cam gear is actually 180 degrees from where it would be at TDC for cyl 1 (one more crank revolution). So, you are probably way advanced (about 45 cam degrees). See that large notch on the front of the cam gear? It is supposed to be up in front of the V-groove in the plate behind the gear. There is a tiny V-groove on the back edge of the gear that lines up with the leading edge of the large front side notch. That should line up with the V-groove on the plate behind the gear.
You need to do a timing belt job with correct timing and then check compression to see if there is valve damage. Also, you need to identify what cut the belt before you install the new belt. Hopefully somebody like Villhuer will help you.
Bill, your I concur with your diagnosis 100%, that big jump in timing means almost certain damage to valves though. I'll redo the timing and check the compression over the weekend. "Fortunately" I do have a spare set of 32 valves
so turn the crank to 45 deg this is confirmed when the keyway is pointing at 3 O clock.(while standing in front of and facing the motor)
Find out what caused the belt to be damaged and fix this.
Fit a new belt, do a compression test, if you have compression fit the plugs and try to start the car
Small update.
The belt was torn because the crank collar was installed the wrong way and the timing was off because it was incorrectly set at 45 instead of 0. Most likely both heads have valve damage as you can't rotate the engine with wrench anymore.
As a bonus, upon closer inspection one of the spare heads (with working valves) I have has been ruined with some sort of an attempt of porting the intake channels. Sometimes I wish that learning wasn't so expensive.
You have our sincere sympathy. I'm going to agree with you that you have some bent/stuck valves. Cheapest solution is to by a good used motor out of a wreck, commonly sold for about US$3500.
Heres a couple engines (1987)on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...111029761&rd=1
Anybody deal with these people before?
