Help. Air box on '83
If you are talking about the air plenum that holds the air filter, on 83 + 84, The "inlet horn" has 4 additional bolts, which should be visible to you. They also need to be removed. 10 mm. A little contorted to reach.
No I didn't get it out. Looking down inside the center of the box reveals a round plate that is flush, no opening visible. The PET shows a third bolt (hex head) front and center for the 83 Euro, but mine has a molded hole that is three or four inches deep, in the front of the box, with what looks like an allen head at the bottom. I didn't want to be turning something that didn't make sense to me.
I was trying to remove it to zip tie the heater valve closed. I managed to get it done with the air box on, but I wouldn't recommend the contortion act to anyone.
Duh!!! Now I get it. I saw that bolt head on the Spyder body and the shaft of the bolt down below running through the foot of the box and still managed not to put 2 and 2 together. Thanks Rich.
How can I be so smart when reading playboy and so dumb when reading a parts manual?
