928 Forum 1978-1995
Sponsored by: 928 Specialists
Block plug question
Old May 3, 2008 | 12:45 PM
6.0-928S's Avatar
6.0-928S
Default Block plug question
In the valley of the block between the bosses for the knock sensors there is an allen headed plug. I assumed this went through to the crankcase but I managed to crack it open & there is a bulkhead about an inch or so below the opening. Does anyone know if this is a water jacket or just a supporting wall for strength or? I was going to use it for an oil drainback hole but I'm not sure if it goes through to the crankcase or......?
Thanks, Hammer
Old May 3, 2008 | 12:56 PM
BC's Avatar
BC
On my S4 block it is a threaded hole that goes to the main crankcase area, though you may see the supporting structure of one of the main bearings.
Old May 3, 2008 | 02:46 PM
Vilhuer's Avatar
Vilhuer
No water in there anywhere. It will drain on top of crank thrust bearing.
Old May 3, 2008 | 05:16 PM
6.0-928S's Avatar
6.0-928S
Great! Thanks guys. With the engine in the car now I couldn't check for myself.
Regards, Hammer
