Oil pan stud kit
Chronic Tool Dropper
Dear Dr Bob, I got the nuts of using a flex head wrench with a medium sized vice grip on the end for leverage.
I was hoping to avoid dropping the crossmember to drop the oil pan. The plan is to raise the engine with engine brace I use for motor mounts. But, in all likelihood I will drop the crossmember in the end.
I continue to believe the studs are too long and I believe I will try to find a shorter version.
I have a silicone gasket on the shelf. The cork one I installed failed. Not sure why yet.
The person who has used a servohydraulic materials testing machine (e.g., MTS) will think of the tightening problem as a decision between using load or stroke control. I think this is a case where stroke control is best.
You don't really care about the torque on the nuts, or even the axial load in the studs - you are aiming for a certain elastic displacement of the gasket, a certain amount of "squeeze". If we had the mythical friction-less system, we could use torque, but between the lock nuts and the low loads, we are very distant from that in this case.
How to introduce the right "squeeze"? The clever person would consult the application engineers, get the suitable displacement range required in the gasket, do a calculation from thread pitch, and do a "snug plus so many turns" operation. The snugging operation is rather delicate and tricky, however; if one nut inadvertently deforms the gasket during snugging, it will throw off its neighbors. Some of the nuts have to be moved just 1/6 turn or even 1/12 turn at a time. It would be so easy on an engine stand....
This is what the embedded hard washers in some gaskets are for - assuring a certain displacement. The cam cover bolts use this approach of assuring a certain displacement regardless of torque. The washers will, however, frustrate the person who hopes to snug up a leaking oil pan 20 years later.
Me, I used the recommended torque to get a sense of how much displacement was required, plus years of experience opening and closing jars and bottles with various seals. Then I went 'round and 'round, trying to get this displacement evenly - by feel, by eye, by instinct, by discipline not to over-tighten - no unsightly bulges! I will not claim to have done it with German precision, but it doesn't leak.
"Stroke control" is the required method for the silicone gasket, no question. In a perfect world, the gasket would arrive with spacer sleeves at each hole, and you'd torque the bolts to keep them from falling out, knowing that the spacer maintains the correct amount of squish on the gasket.
The cork gasket -can- use a torque setup when it's brand new, the threads in the girdle and on the bolts are clean and not worn, etc. But the method involves an iterative tightening sequence that sneaks up on the desired tension. Once the cor gasket is heat-cycled a few times and exposed to oil, no easy way to tell what the correct torque number is to get the perfect amount of compression for a seal without distortion or squeeze-out.
Curt, if it seals for another 100k and the bolts don't fall out along the way, I call it good.
My late mechanic instructed me to look for the cork gasket to slightly bulge. The studs without spacers and with compression nuts does slow me down.
