Front spoiler removal question
I have limited time today to work on my front fender repair. I have to daily drive my 928 for the next two weeks (family member needs to borrow my DD).
Anyone know how long it takes to remove the front spoiler, I have only 1.5 hours after work till I have to pick-up my son from school. I don't want to start removing it and not finish, any tips on the removal? I did a search and could find much info.
Thanks.
Thanks.
Supercharged
It would be close. IIRC, you need to remove the fender liners to get at a couple of screws. But if I'm wrong, it should just be a matter of removing all the screws and sliding it off, in which case you can probably get it off in 10 minutes.
Watch out for wacky re-installation(s) someone may have done on it in the past. When I took mine off, I had quite a bit of extra work to replace missing fasteners and straighten everything out.
Archive Gatekeeper
There's a pic about the spoiler in a writeup I did here:
https://rennlist.com/forums/showthre...hlight=spoiler
Basically, once you get all the screws out, it pulls straight towards the front of the car off some big tabs that hold it on/in.
Owns the Streets
Needs Camber
Needs Camber
I hate those buried behind front fender liner screws.
Didn't have Rennlist help and finding out about those hidden screws sucked.
