Strange battery drain / problem.
Man, is that ever the truth (learned the hard way)! Thank you for the follow-up.
Then, it started throwing the fuse (which is actually when I narrowed down the light). I called Dave at 928 Specialists and he knew instantly that the overhead light was the problem. Sure enough, it was and quickly remedied.
You may have checked this already, but just throwing in my $0.02 in case it helps.
For $20 (radio shack) you can get a DMM that will make the process much easier - I wouldn't start without one... But if it worked for you - good!
I actually have 6 multimeters 2 old analog ones, 2 DMM's and 2 clamp meters each has its uses and one of the analog ones is a dinky little minature thing I keep in my travelling kit - no batteries to worry about (just in case).
Alan
Its obvious you have an issue that the trickle charger/maintainer doesn't work correctly and tells you you have a faulty battery.
I understand you don't drive the car often and thats why you got the maintainer - however if the car holds charge for 3-4 weeks (sufficient to start the car OK) and then is getting close to the edge - thats not so odd - it may well be considered fairly normal. If the car totally discharges in 2 weeks you probably have a problem.
Here is some math: Battery is 75Ah, you'd never want to discharge to more than 50% so you have 37.5Ah to play with. If the car has a parasitic current of 50mA (a little high but not too bad) then in a week (168h) you deplete ~8.4Ah so you will deplete half the battery charge in ~4.5 weeks.
Maybe you don't have a real problem with the car - just the battery charging? (of course you also have the problem that you don't drive it often enough!)
Alan
You're absolutely right about not driving it enough! I'm ashamed of myself sometimes when look at the shark for not using it enough.
Back on topic, the battery will be dead flat in around 2 weeks - ruined my last one as the voltage dropped to 0.8v! Hence buying the battery maintainer to try and save my battery from complete discharge. I do definately have a problem with drain and fully intend to isolate it. I've just been after a short term fix as i'm fed up with jumping in the car and getting nothing so much as a click when i turn the key.
