Performance chips....Always in pair ????
I had to remove both the LH and EZK from my car last saturday. So I decided to take a look at the chips to see if there were original or else. I found one SuperChips in the EZK (ignition module) both none in the LH module (it still have the original one number # 2 287 355 447).![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I always believe that the chips were coming in pair for the Porsche 928![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
The car runs great as is so …![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
The number found on the chip:
SuperChips
928035
11466 10-11-95
SuperChips
928035
11466 10-11-95
Chips that were mapped for manual cars suffer from low idle when used in auto cars due to a lack of idle control when the car is in gear but stationary.
Perhaps the PO recognised the issue and re-installed the OEM LH chip.............thats what I did. I have GT mapped chips.
Malcolm,
Any HP gain with that configuration? Superchips claim 10 HP.
Is it possible that you received 25 cm of snow today? 20C in Montreal today
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
hi Luc.......The GT mapped EZK chip certainly changed the power to a higher rpm range and 'seat of the pants' hp gain. I assume that this map was used to take advantage of the GT cams.
Yes we got dumped on again; snow in April must be Spring in Canada.
Bon chance avec Les Habs!
