RDK wheel sensor
Basic Sponsor
If the sensor is still avaiable from Porsche I can supply it.
It may be cheaper to buy a used one from someone on the board.
I can check price & availbility tomorrow.
Best,
Roger
Roger@928sRus.com
Best,
Roger
Roger@928sRus.com
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Archive Gatekeeper
Front or rear? The rear D90's have/had a 3 bar (44psi) sensor while the fronts have a 2.5 bar sensor. IIRC the bar value is embossed on the tan face of the sensor. All the Cup rims with RDK have 2.5 bar sensors, front and rear, so they'd theoretically be more abundant.
They're held in with a threaded ring, and of course there's a special 4 or 5-pin socket to undo it. But you can proabably get it off with a bigass channel-lock pliers. The little plastic cover over it (928.361.201.02) will proabably break while you try to take it off (just twists off, snaps back in place). They're made of the same plastic that Bosch uses in their engine sensor connectors. There's also an o-ring in/on the sealing face (999.707.035.40) that you'll want to replace.
BTW, how do you know you have a bad one (unless if has obvious damage?)
They have a whole box of them at 928Intl. The bad news is that they're hideously expensive ($350+ new at 928GT.com) you could probably find a used wheel in bad cosmetic shape that has 2 sensors in it for less than one sensor would cost. I sold a set of 4 crappy D90's (with 8 working sensors in them....) last year for $300.
Dean of Rennlist, "I'm Listening"
When you get sick and tired enough of them, you'll throw the damn things away.
That's what I did! Fixed the problem very nicely.
