Rear Hatch rattles and sqeeks
My rear is noisy. Anyone have any quick fixes?
Support pistons are new.
Thanks,
Chris Hansen
1981 928
2007 Mini Cooper S
1968 Mustang (son's)- restored- sort of
2006 Suzuki Aerio (daughter's)
2003 Honda Pilot
Thanks,
Chris Hansen
1981 928
2007 Mini Cooper S
2003 Honda Pilot
Under the Lift
Use silicone grease on ALL the rubber surfaces. Lightly applied and rubbed in well so that it essentially disappears, it is not messy at all. One widely available brand name is Super Lube synthetic grease. Take the support pistons off and grease the posts. Put a little grease on the latch mechanism where the upper latch makes contact with the lower. We just did all of this on Nicole's car and it got rid of the squeaks.
In later models there are pieces of teflon tape opposite the rubber guide wedges. You can buy the teflon tape pieces from our favorite 928 part vendors.
Check the rubber bumpers at each rear corner of the hatch. Twist them out a bit to raise the hatch relative to the body and see if that quiets the rattle. If the rattle goes away and the hatch is still level with the body, great. If the hatch now rests above the level of the body, remove the Allen bolts from the lower hatch latch (the receiver) and see if there is a plate/spacer underneath the top flange area. If found, remove it and readjust the rubber bumpers. If the hatch is now level with the body and doesn't rattle, great.
If you can eliminate the rattle only with the rubber bumpers set so the hatch is jacked up above the body, then consider replacing the plastic tongue in the upper latch mechanism. It tends to wear either externally or in its pivot hole, necessitating the jacking up of the hatch to stop the latch from rattling. It is held by a pin that must be drilled out. The upper latch should be removed from the hatch first so it can be disassembled. The end of the new pin will need to be peened so it doesn't come out.
It can help to have somebody drive your car down the street while you lie in the back so that you can pinpoint the noise source. That's how I found that my rattle was from the latch. Replacing the tongue fixed it. Another source of rattle that just happened to me is a loose top nut on one of the rear shocks.
Mine drove me nuts. I tried all the above, but it only fixed when I fitted a liner to the rear receiver.
You do have the liner in place DONT you???? softish flexible off-white lining. Makes all the difference.
No, they are NOT available separately!!! You have to buy a complete receiver...
jp 83 Euro S AT 51k
jp 83 Euro S AT 51k
Under the Lift
Silicone grease is used to safely lubricate rubber without deteriorating it like pertroleum based grease.
Under the Lift
jp 83 Euro S AT 51k
jp 83 Euro S AT 51k
Chris,
You have an 81 and I'm assuming your hatch seal is original?? Does it leak into the rear seats while you are washing the car or after you open the hatch after washing? You probably need a new hatch seal. I replaced the teflon hatch pieces, then adjusted the rubber bumpers on my 79 and nothing seemed to work. Got a new hatch seal because it was leaking-no more rattles!!
Thanks for the tip. I ended up working on the '68 Mustang today, but tomorrow that hatch is quieting down! Had to get a Mustang project finished, or my son would be driving the 928 to school. That's motivation!
With all the tips, I'm sure I'll defeat the squeaks.
I suffered with a noisy/rattley/squeeky hatch for years. Tried every fix under the sun with no permanent results. I finally bit the bullet and replaced the entire tongue and receiver assemblies. Problem solved. The key to the whole thing is that the hatch must shut and latch down with extreme tightness which prevents any unwanted movements of the hatch in all dimensions.
Nine2Eight
87 S4 Diamante Blau
Tampa Bay, FL
Nine2Eight
87 S4 Diamante Blau
Tampa Bay, FL
Under the Lift
Nine2Eight
87 S4 Diamante Blau
Tampa Bay, FL
Nine2Eight
87 S4 Diamante Blau
Tampa Bay, FL
