Warm up regualtor... Which one????
Hi all,
I warm up regualtor has just gone south <img src="graemlins/crying.gif" border="0" alt="[crying]" />
I was wondering if i should go for the Original Bosch Warm Up Regualtor ($224) or the adjustable fuel regulator ($175-$199)
My car is an 1982 928S Euro spec
Any suggestions appriciated
Thanks,
sparky <img src="graemlins/c.gif" border="0" alt="[ouch]" />
Thanks,
You may be confusing the warm-up regulator with the rising rate fuel pressure regulator.
The warm-up regulator in your K-Jetronic (don't be fooled, this is a mechanical system) enriches the mixture when the engine is cold and also when the throttle is wide open. The system pressure is controlled by a regulator built into the fuel distibutor. The rising rate fuel pressure regulator is not for K-Jetronic systems.
In the electronically-controlled L- and LH-Jetronic systems fitted to 928s, the injectors for each bank are supplied fuel from a common rail (pipe). The fuel in the rails is controlled by a pressure regulator; the rising rate regulator can be substituted for this to improve the response under load without sacrificing behaviour at idle.
