Coolant Selection
After seeing what happened to my heads, I will never let the green stuff come close to my car. I now only use the Zerex G-05.
Draining the block is messy - get ready to run! There just isn't a pretty way to do it. Then stick the garden hose in and flush the hell out it. Replace teh drain plug, and fill back up with G-05 antifreeze.
I ask because the Prestone "Mix with Any Coolant" has a green hue although it's been reccommended by many.
You got the correct answer many times. DRAIN THE BLOCK, flush with water and use ZEREX G05. G05 is the OEM AF used in all Fords and Chryslers. I have used it in many 928s for years and it works fine. Install 2 gallons (undiluted) first and then add distilled water to fill. That way you get the proper 50/50 ratio. DO NOT use the stuff with the water added. There is always some water left in the system after flushing and you end up with less than a 50/50 ratio.
Received 1,609 Likes
This horse was most recently beaten here:
https://rennlist.com/forums/928-forum/404881-green-yellow-orange-which-coolant-is-right-for-our-cas-read-here.html
The Prestone "Mix with Any Color Coolant" is the Long-Life coolant Bill Ball refers to above. I venture to write that it, along with the Zerex G-05, have been given the Rennlist Seal of Approval (RSoA)
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Chronic Tool Dropper
The stuff I'm using now is the Zerex G-05. It's almost water-clear. Here in the tropical desert climate of SoCal I run a gallon in distilled water, plus one bottle of Water Wetter.
The Water Wetter helped immensely on my Explorer when it was doing summertime towing duty across the deserts to Arizona. Daytime air temps 120º-plus, with a trailer-load of water toys, black truck. Sitting at idle with the AC on max, the temp would drift up towards overheat on the gauge. Rev the engine slightly and the airflow would improve and avoid boilover, but still... A bottle of Water Wetter added, and suddenly it could sit for extended periods with the gauge just a little higher than normal. No worries at all about heating after that. So I'm a believer, based on my own first-hand experience. My 928 has never had any heating issues, but then again it's never been without Water Wetter in the years I've owned it. IMHO, it's about the cheapest $8 insurance you can buy.
Whoops... meant Bill Ball not DrB. Sorry Doc.
A Wet Vac will get that coolant out fast and easily without having to go after the block drains. Gets the vac nice and clean too. I use the radiator hose and put a drain pan underneath to catch what comes out when the hose gets pulled.
Good idea on the wet-vac. You'll still want to pull the block drains to get any sediment out of there, but after the coolant is out a little bit of water flushed through there isn't nearly the same mess.
Under the Lift
Under the Lift
How do you use the wet vac to get the water out of the water jacket around the cylinders? Do you thread a long hose into a low spot inside the block?
Bill--
The wet-vac idea is to attach the hose to the top (non-thermostat) side, then open the block drains. The massive velocity of air rushing through the block drains will carry the remaining water out the top...
Seriously, putting a little negative pressure (it's all relative...) at one spot will draw a lot of the fluid out. I'd be tempted to try it at the top after draining the radiator and heads the 'normal' way. Flush with a LOT of water through the top hose into the block. Then open the block drains while using the business end of the wet-vac to try and capture the outflow.
I do the drain-and-flush-and-drain routine now, minus the wet-vac. I have a couple very large dishpan-like trays that go under the engine, so most of the draining fluid is captured there anyway. Any stray is wiped up with a towel. The floor is cleaned after these events anyway. For the most part, I concede that there's some cleanup, plan on washing the coveralls, etc.
Coolant is due for change early summer, and brake fluid is due about then too. Auto trans will come up end-of year. Might be time to just put the car up once, do everything, and call it a day. There's room for a couple cars in there at the same time, so maybe a mini-clinic is in order. Since I will have to wash the floor anyway. I still need to get that wheel bearing tool and do the rears. Might be a l-o-n-g day.
