Adhesive for door panel upholstery/pleather?
Hello,
I have started my interior restoration project and I need some advice. My door panel pleather has started to come off of the panel and I was hoping someone could recommend a good adhesive for reattaching it. Thanks in advance.
Erik, I had the same question when I started my int. project, I e-mailed 3M and told them I needed something that can withstand the heat and cold, they said their General Trim Adhesive 3M #08088 would work good on the flat areas and the Super Trim Adhesive #08090 should be applied on the back side where you wrap the leather around (I don't know why you couldn't use the Super Trim on the whole thing but I'm only relaying what they said). I'm still at the new carpet install and have only used the General Trim so far. BTW the adhesives come in spray form and can be bought from auto paint suppliers.
Good Luck
Good Luck
