Turn signal assembly
Hi all;
Hope you can help. Discovered that driver's side turn signal lens does not fit snug against the black plastic housing (turn signal frame is pushed too far in) but the frame is not bent. Can see no readily available way to adjust this from outside. Any similar expereinces, suggestions? The passenger side assembly is fine and looks the same as the driver's side, except the driver's side is about 2 inches too close to the radiator. Any/all help is appreciated.
REC
Garnet 85S auto
REC
Garnet 85S auto
