ezcar lift
hello, i am trying to get a group buy on this lift for 1625.00 delivered to your door. before you consider the price look at the lift and its benifit. i know there are other lifts out there but this lift has the mobility that other can not even come close to. please see this web link from an owner and his persone reviews. http://mysite.verizon.net/vze7aq8e/continued/id25.html
the web site for the lift is ezcarlift.com he has some videos of the lift but not as detail an the above listed owner reviews.
Craic Head
No offense, but that thing doesn't look very strong to me. I wouldn't crawl under it. And if I'm getting a lift, it's going to be so I can walk or park another car under it, not so I still have to use a creeper.
Bumbling Neophyte
I just bought a kwiklift, about $1550 delivered. Makes this thing look like frilly girly lift for a barbie car. Kwiklift is heavy duty and I have no problem scooting around under it. I can get it up in less than 5 minutes!
KK
KK
Rocket Pilot
Craic Head
No affiliation. (and I haven't gotten one yet, so if you find one, post your results).
Is Rixter out there? I think he bought one a while ago, but he had to do some work on his floors or something before he could put it in. Rixter?
I think you can get one of these for about $1500. Not quite so compact, but it appears much more stout.
http://www.bendpak.com/cart_product_...=260&cat_id=49
I've been eyeing one of these. Anybody have any experience with them?
http://www.gesusa.com/category/parki...ng_storage/431
I got this one a year ago for about $1,250.00. It goes on an even deeper cut sale regularly (deeper than the indicated $1,395.00. I'm really happy with it. Solid as a rock.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
http://www.americanautomotiveequipme...-p/tp09a-d.htm
Shipping is a big issue. I was able to pick this one up in Indianapolis so I saved that cost as well.
Rod
Rod
Four posts are more obviously stable, but two posts provide less obstructions to the undercarriage making some jobs easily. The four post lift from the wheels, so suspension work is not easily done with this lift. Even changing a tire requires some other means of lifting.
Other than that, I'm not sure there is a big difference. I obviously like the two post much better.![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Rod
Rod
Craic Head
I'm leaning toward the four-poster because:
* you can store a car on it and another underneath (not sure if this is an option with the two-poster, but I don't think I'd feel comfortable with it.
* you don't have to 'line up' the car to make sure the balance points are right like you do with a 2-poster. With a 2 poster you need to make sure you hit the marks pretty well right on, or you can have too much weight forward or back.
* you don't have to get on your hands and knees and line up the lifting arms each time you want to raise it (unless you're specifically lifting to work on the wheels)
* most four-posters don't require you to drill your concrete floor and permanantly mount the lift. A lot (but not all) of the two posters require this and that the floor is pretty thick where it's mounted which might require a re-pour and reinforcement.
These are just the reasons I've got and my perceptions. YMMV
Administrator - "Tyson"
Mike,
There are no issues storing a car under a vehicle on a 2-post other than fluids dripping. Unless you have a full floor on a 4-post (most do not) they also have the same problem.
