928 Forum 1978-1995
Sponsored by: 928 Specialists
Pump or Rack?
Old Feb 18, 2002 | 01:11 PM
John..'s Avatar
John..
Post Pump or Rack?
The steering in my 81 started making a groaning noise. It seems to be the worst when the car is cold. Anybody have experience with this in the 928? My gut tells me it is the pump, but could it be the steering rack?
Old Feb 18, 2002 | 02:32 PM
Snowball the 81 white 928's Avatar
Registered User
Post
1 vote for pump.
Old Feb 19, 2002 | 02:05 AM
jpitman's Avatar
jpitman
Post
I have had this in other cars too. It was caused by low on oil, or the reservoir to pump pipe was obstructed. On my Disco, the jack vibrated up on to the hose, and flattened it - loud groaning noises. Check your hoses for kinks, leaks, collapsed, and finally, delaminated internally, blocking flow.
jp
Old Feb 23, 2002 | 01:05 PM
Jim A's Avatar
Jim A
Post
Did you figure it out? I started having the same problem last week, also only when motor was cold. By cold, I mean 65 - 70 degrees, here in Orlando, FL...in February.
Old Feb 24, 2002 | 12:14 PM
John.'s Avatar
John.
User
Post
It is still doing it.....I did add some fluid to the system, since it was low. It also make a noise on right hand corners at a certain RPM. You can actually feel it through the wheel on an on ramp. I don't know, but my gut tells me it is the pump. I sure hope it isn't the rack!
Old Feb 24, 2002 | 12:43 PM
Steve Cattaneo's Avatar
Steve Cattaneo
Post
John,
If you have a lack of assist with turning when the weather is cold, but your steering feels fine when it’s hot, and your belt tension and fluid level is right, it is the rack.
Good Luck,
Steve C
The Great White
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
