DIFFERENTIAL SERVICE 88S4
PEOPLE,
i HAVE A88 S4 AUTO TRANS i WANT TO SERVICE THE DIFF. CAN i USE SYTH GEAR OIL i THINK IT`S SJ FLUID QUAKER STATE IS THAT OK
You could use synthetic gear oil, if your not sure weather you have limited slip differential, just add posi-lube additive to the oil. Any parts supply house sells it, it comes in a 16oz tube. You will not harm your differential by adding this lube if it’s not limited slip.
Good Luck,
Steve C.
The Great White
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Good Luck,
Steve C.
The Great White
