928 Forum 1978-1995
Sponsored by: 928 Specialists
Batttery/Alt Voltage Meter Reads 16 Bar
Old 12-30-2002, 09:48 PM
Drewster67
Drewster67's Avatar
Post
I went down to my local Autozone -
They tested both my battery and alternator -
Test Results -
Battery - Good
Alternator - BAD DIODE
Looks like I need to find a Refurbished/New Alternator.
I did inquire with them and they have 5 Types available (Special Order Only) and depending on which alternator came as OEM.
Beck/Arnle
90 Amp - 195.10 w/60.00 Core - 1 yr warranty
for 928s w Paris-Rhone Alternator as OEM
80 Amp - 222.98 w/85.00 Core - 1 yr warranty
for 928s W S.E.V Marchal Alternator as OEM
75 Amp - 179.91 w/25.00 Core - 1 yr warranty
for 928s w Bosch Alternator as OEM
Duralast
90 Amp - 200.99 w/50.00 Core - Life Warranty
for 928s w Paris Rhone Alternator as OEM
90 Amp - 149.99 w/45.00 Core - Life warranty
What would it matter which alternator came as OEM?
Thanks Again
Old 12-30-2002, 10:03 PM
Incendier
Incendier's Avatar
Post
Hey Drew...go to <a href="http://autoexpress.safeshopper.com/688/cat688.htm?75" target="_blank">this web site</a>. I'm a customer and very happy with the reman product, the quick service and the price. (no other interest in the company)
Or, you could just replace the voltage regulator.
Old 12-30-2002, 10:12 PM
Drewster67
Drewster67's Avatar
Post
Right On !!!!
Thank You ever so Much!
Old 12-30-2002, 10:37 PM
Old & New
Old & New's Avatar
Post
Maybe not so, guy.
The Paris-Rhone has diodes separate from the regulator.
- the *anonymous* Old & New -
Old 12-30-2002, 11:06 PM
Drewster67
Drewster67's Avatar
Post
Damn - Just when I thought I was in the clear!
BTW - Mr Anonymous O&N - I didn't catch your definition of what a Bar meant - Thank You. I'm a little slow at times.
After doing a physical inspection of the alternator, I was unable to determine the manufacturer.
I guess I shouldn't <img src="graemlins/crying.gif" border="0" alt="[crying]" /> about it, so I might as well have a <img src="graemlins/drink.gif" border="0" alt="[cherrsagai]" /> , maybe with a <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" /> ,then go to <img src="graemlins/sleep.gif" border="0" alt="[sleep]" /> . Tomorrowa another day.
I'll <img src="graemlins/yltype.gif" border="0" alt="[typing]" /> the outcome tomorrow.
Thanks again Everyone <img src="graemlins/bigok.gif" border="0" alt="[thumbsup]" />
<img src="graemlins/r.gif" border="0" alt="[king]" />
Old 12-30-2002, 11:32 PM
Ted928
Ted928's Avatar
Post
Drew,
Do yourself and the followers of this thread a favor and take the advice that has been given to you on multiple occasions. Accurately measure your voltage using an accurate voltmeter and post it (engine off, engine running under low electrical load, engine running under full electrical load).
I would not buy a new alt based solely on Autozone's advice.
Old 12-31-2002, 02:22 AM
Normy
Normy's Avatar
Cool
Beck Arnley vs Duralast alternators?
OK....I thought our alternators came from Bosch and Marchal.
-VW's use quite a few Bosch alternators, and the main difference is the mounting points. I think I red on here some place that someone found an Audi alternator that fits at a lower price.
-And I'll look for the link later, but I remember reading in European Car an article that detailed replacing the integral voltage regulator on a Bosch alternator with an external Ford unit that was way cheaper and worked better anyway.
Normy!
'85 S2 5 Speed
Old 12-31-2002, 01:37 PM
Dozman
Dozman's Avatar
Post
Normy,
If you find the link keep me posted, seems like a good mod to do next year.
John D
Old 12-31-2002, 01:40 PM
Randy V
Randy V's Avatar
Post
Typically, our cars use an alternator from either Bosch or Paris-Rhone.
Make sure that the alternator you get (if replacing the entire unit) will accept the cooling air shroud assembly.
Old 12-31-2002, 02:22 PM
Drewster67
Drewster67's Avatar
Post
Autozone uses BEAR testing equipment - The same test equipment as the Porsche Shop I used previously. Don't let the name AUTOZONE fool you -they have the most modern testing equipment.
I have no reason to doubt the results.
Normy, thanks for the heads up, I would be curious to see what you find out.
Old 12-31-2002, 03:57 PM
Jimbo
Jimbo's Avatar
Post
Some repair shops will repair your alternator for much less than a reman unit.
Old 12-31-2002, 04:07 PM
Dozman
Dozman's Avatar
Post
This is so true. I took my alt. to a local alternator rebuild shop. The repair cost me a $100.00. Can't beat it. It's been on the shark for over 6 months.
John D
Old 01-01-2003, 11:10 AM
Old & New
Old & New's Avatar
Post
Randy,
I had replaced the Paris unit on my Euro with a Bosch unit. The Bosch factory rep told me that the shroud was not required, and it did not fit the alternator that they sent me.
It has been a few years, but I remember that Bosch offered two different units that fit the car (one was their #315 model). I think that one of them was a rebuild and did accept the shroud.
Of course, not using the shroud required finding a nice airflow spot for the temp sender that lives in the shroud hose.
Old 01-01-2003, 12:36 PM
Donald
Donald's Avatar
Post
Picky irrelevant point: a "bar"~ 14.7 psi, not 20 psi
Quick Reply: Batttery/Alt Voltage Meter Reads 16 Bar
