928 Forum 1978-1995
Sponsored by: 928 Specialists
DFW engine tech session suggestion
Old Mar 25, 2008 | 01:11 AM
docmirror's Avatar
docmirror
Shameful Thread Killer
Default DFW engine tech session suggestion
For the box-a-rox that hang around DFW, I will be assembling the lower end of my GT this weekend. As I have never done a 928 engine, I was going to make a tech session offer out of it.
Work to be done:
1; Install crank in case, with seals, flywheel and torque girdle.
2; Hang rods, install rings, bearing shells.
3; Install piston/rod asm in case and torque.
4; Install oil pump, pickup tube, water pump, knock sensors, TPS.
We can do it at my place way out west, or we can do it at a more - shall we say, metro-centric location? I'm hoping Sterling will visit, as he's done this before. I'm sure we can struggle through if not. All are welcome, however, more than 4 or 5 around one block will get a bit dicey.
RSVP here, if you're interested. The balance of the top engine will go together the following week, prolly out at my place over the week.
Old Mar 25, 2008 | 06:29 AM
ROG100's Avatar
ROG100
Basic Sponsor
I'm in for some of the fun.
Good time to get rid of that POS gearbox at the same time 8>)
Old Mar 25, 2008 | 10:07 AM
BPG_Austin's Avatar
BPG_Austin
Doc, when are you going to be wrenching? I'm looking for a roadtrip this weekend and would, schedule permitting, like to make the trip up there from Austin.
Ben
Old Mar 25, 2008 | 10:14 AM
docmirror's Avatar
docmirror
ROAD TRIP!!!! FOOD FIGHT!!!! Sorry, didn't mean to shout indoors.
I guess I'll start around the crack of noon, or maybe a bit sooner on Sat 3/30. If we have some inspiration from Sterling, and follow the book fairly carefully I can see about 3-5 hours of work. More or less depending on the amount and type of beer consumed. I'd like to get it to the point of being able to spin the oil pump and see the oil circulate a bit.
If there's interest, we could also attach the heads time permitting. That part of the job requires a bit more energy, and we may not get to it, but I'll have them along in case.
Old Mar 25, 2008 | 10:16 AM
docmirror's Avatar
docmirror
And where, my good man would you like to enjoy this fun? Out west, or someplace - hmmmmm, closer in.
Old Mar 25, 2008 | 10:39 AM
BPG_Austin's Avatar
BPG_Austin
Doc, sounds like fun if you don't mind an extra person watching the progress. The finace is having a bridal shower and I GOTTA get out of Austin. Will be watching for location and details.
Old Mar 25, 2008 | 11:16 AM
David L. Lutz's Avatar
David L. Lutz
Doc,
How far are you from the Dallas FT. Worth Airport. I am thinking about coming if I can talk the wife into it and depending on the $$ of the ticket.
Old Mar 25, 2008 | 01:32 PM
docmirror's Avatar
docmirror
Well, I've twisted Roger's arm enough, and it looks like we'll be at his place. It's costing me a kidney though.
Roger's is a short distance from the DFW airport. I am more than an hour away. someone could collect you David I'm sure, or you could grab a rental and be there in about 15 minutes.
Sterling, I haven't put the rings on yet, and would do that as soon as I got the pistons, everything is still at the machine shop. I'm supposed to collect the block, crank, girdle, and rods tomorrow. I'll not get the heads in time to do that this weekend but the lower end should go together well. I have access to a ring compressor, or maybe I'll just buy one for Roger.
Pete(machinist) and I were looking at the oiling passages in the girdle and I'm going to do a bit of cleaning up of the casting down there. some of the return galleries have flash on them, and the intake passages have some sharp ridges I'm going to radius, and maybe increase the main journal via a bit that services the 2/6 rods. Just a light cleanup of the oiling paths to reduce flow restriction. This will hopefully be done before I get to Rogers house, but it may spill over a bit. I need to get it done in advance so that I can fully clean it before installation.
We have paint pens, and I'm buying the girdle goo tomorrow.
Looks like a go. Hope Curry comes over and gets his damn stinkfoot shoes.
Cya all soon!
Old Mar 25, 2008 | 01:33 PM
soontobered84's Avatar
soontobered84
David, There will lots of ways to get you there from the airport. I will probably go and I am close by the airport.
Old Mar 25, 2008 | 02:29 PM
docmirror's Avatar
docmirror
Thanks, I wouldn't have thought to check the expiration on the goo. The block is being cleaned very carefully by the machine shop. He's got all kinds of stuff to get it done, and blown out. It wil be ready to go when I get it back. So, although taking a shower with my engine sounds kinky, I think I'll pass.
Old Mar 25, 2008 | 02:57 PM
RyanPerrella's Avatar
RyanPerrella
By goo do you mean the Loctite 274 is it? I dont know if the number is correct but your talking about the specified Loctite for the case halves correct?
I would love to come, but don't think I can make it this weekend.
Maybe you can give one of the guys a camera to just focus on shooting everything and you can start a good picture based thread on this. I have 200 or so photos from my engine build that I want to put on on Flicker or something. I know allot of guys on here would love to see a fresh, clean 928 block and the steps involved in doing this. I never separated my case halves thinking i could do more damage then good, so I am very curious to see what kind of fun you get into.
As for piston ring compressor any one should do. If i had to do it again though I would buy a ring compressor thats low profile. From the top ring to the bottom its probably about 2". The Ring compressor I have is like 6-8" tall. It's somewhat clumsy and larger then it needs to be for our cars, so if your looking for a ring compressor, i would look for a low profile one as thats all you will need.
Old Mar 25, 2008 | 05:19 PM
RyanPerrella
Sterling,
Ive seen the page before, i love your site BTW.
I just realized your block looks dull or rough as opposed to the factory which almost seems polished. Is this what happens when US Chrome does their thing? Do they put it in some type of chemical bath that etches the aluminum block or something?
Old Mar 25, 2008 | 10:11 PM
SeanR's Avatar
SeanR
You know I'll be at Rogers anyway on a Saturday, so count me in. If there are too many hands, I've got a couple of projects going there anyway.
Anything I need to bring?
I owe you for dinner, when are we doing your bumpers?
Old Mar 25, 2008 | 10:52 PM
docmirror's Avatar
docmirror
Hey folks, this is shaping up well. Sterling has 'been there done that' so as long as I can reach out by phone he gets a pass on this one.
As for the bumpers, sigh.... My painter is a good guy and does good work, but our idea of 'schedule' is very different. Last I heard, it was going to be ready Thur. which I interpret to mean next Monday, or perhaps Tuesday. I cut him some slack because he's working on his Airframe & Powerplant mechanic rating at school. I'm guessing bumpers next week It looks like I'll be fairly busy the rest of this week.
Old Mar 26, 2008 | 02:28 AM
docmirror's Avatar
docmirror
Okay, more the merrier. I just hope I get a chance to clean off the girdle before we start. I want to clean the flash, and radius some of the oil passage lines before the big glue.
