928 Forum 1978-1995
Sponsored by: 928 Specialists
Skip while under partial load Data logs attached
Old 03-22-2008, 11:54 AM
Kevin Michael
Rocket Pilot
Kevin Michael's Avatar
I she leaning out on decel? Mine stays rich all the time as well, but always leans out on decel. What size injectors are you running?
Old 03-22-2008, 11:55 AM
Tampa 928s
Tampa 928s's Avatar
24 Lb's this problem started after adding the S/C so I'm hunting down what I did to cause this.
Old 03-22-2008, 12:46 PM
Kevin Michael
Rocket Pilot
Tampa, you most likely haven't done a thing to cause this.
Old 03-22-2008, 12:47 PM
Tampa 928s
Tampa 928s's Avatar
Don't want to claim victory but after checking all my connections I went back to my Maf intake.
I repositioned my Intake pipe going into the Maf, after remembering the issue in the beginning that the car surged when it was in too far.
When the pipe from the S/C was in too far it drove the Maf nuts, I pulled, reconnected and checked and car seems fine now, but keeping my fingers crossed.
Did you ever check that amount of pipe inserted in the boot on yours? I believe it causes the air to be caveatted if not in correctly .
Old 03-22-2008, 07:12 PM
Kevin Michael
Rocket Pilot
Never thought of that! Will check it tonight and get back to ya.
Kevin
Old 03-23-2008, 04:02 PM
Tampa 928s
Tampa 928s's Avatar
I am getting a little frustrated trying to track down a skipping issue, now it includes a start-up and stalling issue.
The car seems to change the way it runs everyday.
Today cold start kept stalling until one min or so on feathering the gas.
After shifting, I take my foot off the accelerator and Rpm’s go to zero and stalls, not a very safe thing to do in traffic.
I removed the Lm-3 rake checked all the wires for shorts, replaced the chips with the Auto Auth to eliminate that as an issue. My A/F gauge seems to show rich most of the time while driving. Where can I look to next, I am getting mixed responses as to what the problem could be.
Does anyone have a loaner Maf for me to try, I need to research who rebuilds these and I know its time, but substitute testing is what I want to do for now.
Old 03-23-2008, 04:25 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
Do the 85-86 cars have throttle position sensors? If so, try checking that to see if its within spec. It sounds like a problem I had with another brand of car. Everything pointed to the TPS but it ended up being a shorted fuel injector wiring harness. I know I just contradicted myself but its what I'm good at.
Old 03-23-2008, 05:33 PM
Tampa 928s
Tampa 928s's Avatar
Hi Shawn
No Tps just closed and Wot which have both been tested, with all new Injectors and new connectors. I just need to sub a Maf to put this to bed or continue my journey to insanity.
Old 03-23-2008, 06:56 PM
Tampa 928s
Tampa 928s's Avatar
I found one post on this site for Maf repairs any other recommendations?
Growing and innovating since 1990
Injection Labs was founded in 1990 in Boulder, Colorado, as a remanufacturer of fuel injection components. High demand for its flagship product, the Bosch Air Mass Meter, resulted in the move to a larger facility in Gardnerville, Nevada, three years later.
Old 03-23-2008, 11:21 PM
Kevin Michael
Rocket Pilot
Tampa, dont waste your money on a new MAF ,BTDT. on this same issue. One thing that helped me a lot was replacing that bosch plastic BOV with a high quality Greddy unit that you can adjust. This has eliminated the off the revs stalling. In fact I am using tandem units adjusted for big boost so they simultaniously blow off just a little as to not cause that stalling. You can do it with just one though.
Kevin
Old 03-23-2008, 11:31 PM
Tampa 928s
Tampa 928s's Avatar
After a couple of Wot car barely made it home skipping, surging black smoke A/f shows full rich. I disconnected the Maf smoke went away idle fluctuates a bit and of course wont go over 2K but was able to drive it onto the lift.
Bad MAF?
Old 03-23-2008, 11:33 PM
Tampa 928s
Tampa 928s's Avatar
Humm could it be that the Bov is holding open, the car ran great last week except for the 1/4 second random skip.?
Old 03-23-2008, 11:34 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
Mark,
Louis Ott rebuilds MAF's. He is a rep for John Speake's wares.
Old 03-23-2008, 11:43 PM
Kevin Michael
Rocket Pilot
Or John will send you a Maf to try(with deposit). The bov will not hold open unless it is ruptured. The BOV is a crucial part of how your car will run. A greddy or Vortech unit is much much better.
Old 03-24-2008, 09:44 AM
Tampa 928s
Tampa 928s's Avatar
Thought you would find these logs interesting!
File Type: pdf
File Type: pdf
File Type: pdf
Quick Reply: Skip while under partial load Data logs attached
