928 Forum 1978-1995
Sponsored by: 928 Specialists
Speedo sensor question
Old Mar 16, 2008 | 03:23 PM
Brett Matthews's Avatar
Brett Matthews
Default Speedo sensor question
Where does the sensor get it's info? Front wheels, rear wheels, transaxle???
Old Mar 16, 2008 | 04:04 PM
Mike Frye's Avatar
Mike Frye
Craic Head
I'm pretty sure there's a sensor on the rear axle. What's it doing? If it's not moving at all when the car moves it might just be a problem with dirty connections in the pod rather than at the sender. I think it's grounded at that point in the PS (us) rear hatch area behind the quarter panel.
Old Mar 16, 2008 | 04:30 PM
Brett Matthews
Well, I'm actually considering a different front tire size, 225/55-16, instead of the 225/50-16, as supplied from the factory. There is a difference in circumference, as well as sidewall. fewer rev's per mile. I wonder/worry about fender well clearance as well.
Old Mar 16, 2008 | 04:58 PM
John Speake's Avatar
John Speake
IIRC pre PSD cars the signal comes from the rear diff.
On PSD cars from one of the ABS front wheel speed sensors.
