Water ingestion into MAF S/C car
I had a MAf in for repair at the weekend. It had been used in a c/f s/c car, with the engine air intake filter located under the headlight.
When I took the black cover off the MAF, the reason for failure was obvious - a large amount of water came out. It was clear water, not coolant.
When I queried this finding with the owner he remembered that he had rain water in the intake, and had since made a deflector plate to stop rain water getting into the air filter.
At first I couldn't understand how the water had managed to get into the MAF electronics, because it is sealed where the sensor wires enter the electronics housing. Then I remembered that on later MAFs there is a tiny breather tube - about 0.3mm between the two parts.
Normally there is vaccum in the inlet on a n/a car, so no problem. On a s/c car there is positive pressure and this is what was blowing water into the electronics. I found the black lid was not well sealed, so this allowed the air flow path.
Anyone else with under headlight air filter had problems with water ingestion ?
Anyone else with under headlight air filter had problems with water ingestion ?[/QUOTE]
No problems yet, and I've had mine in a few years now. I think you had my MAF last spring and there were no water injestion issues.
That being said, I avoid deep puddles and try no to be a "U-Boat Commander"!
Jim
Jim
John:
That's very interesting.
On my twinscrew set up the MAF is still on the vacuum side. When I was setting up my fender well install I did consider a fliter wrap, which might be an easier fix than experimenting with a shield.
K & N makes one version of their filter cover that is treated to repel water. As long as the filter was properly sized to begin with this should work very well.
http://www.knfilters.com/wraps.htm
PreCharger/DryCharger Filter Wrap Applications
Below shows a list of applications for K&N PreCharger and DryChargers by part number. K&N DryChargers are similar to PreChargers except they have been pre-treated to repel water. All measurements are in inches.
Best regards,
Ken
Best regards,
Ken
Thanks everyone for their comments. As Stuart said, I also believe that the problem is water running off the headlamp when the car is stationary.
