928 Forum 1978-1995
Sponsored by: 928 Specialists
throttle cable adjustment
Old Jun 30, 2002 | 02:32 PM
Snowball the 81 white 928's Avatar
Registered User
Post throttle cable adjustment
hey, ah, my throttle cable seems to have a lot of slack in it just forward of the spring and the pedal seems to have a "2-stage" (zr-1) touch to it. i assume i need to tighten the cable a bit, should there be some slack in the cable forward of the spring or should it be taut? any other adjustment procedures are welcome.
Old Jun 30, 2002 | 02:56 PM
Jerry 87 928S4's Avatar
Jerry 87 928S4
Post
Maybe this will help?
Old Jun 30, 2002 | 07:06 PM
Registered User
Post
just what i was looking for. thanks for the timesaver.
Old Jul 1, 2002 | 12:14 PM
John Krawczyk's Avatar
John Krawczyk
Post
Check to see if the cable itself isnt ready to snap. Mine did last month. It broke off right where the cable housing ends at the cable stop post under the spider. there was about 3 inches of cable left on the ball end that snaps onto the linkage.
Old Jul 1, 2002 | 04:49 PM
Registered User
Post
now that's just what i need.
Old Jul 1, 2002 | 06:05 PM
LarryM's Avatar
LarryM
Post
I used that same adjustment to set my pedals up for easy Heal Toeing. I moved the gas pedal over just a bit and adjusted the gas pedal to about 1/2 inch below the brake pedal at full braking. The same instructions as Bob Bondurant goes over. Now, at the autocross you'll hear me down shift with close to 0 weight transfer change.
Old Jul 1, 2002 | 07:23 PM
John Krawczyk
Post
No you dont. But if you do, its a 1/2 hr repair and a 50 dollar part. No tools are needed except a screw driver to undo hose clamps and a socket (i forget the size) to remove the bottom half of the airbox.
Old Jul 1, 2002 | 08:30 PM
Registered User
Post
thanks john, your advice is always welcome and of benefit.
