Antenna Coax Wiring Question 89S4
Cruisin'
While replacing rear-seat speakers, I found a loose wire that looks like the antenna coax wire connector - male piece. It's a black 1/4" wire with 1 male pin connector and the connector part is supposed to be screwed into female part. It obviously wasn't screwed together to female part and I must've tugged it loose. Radio no longer finding radio stations so I know it's an antenna part.
Problem - I can't locate the female part of this connector. I've looked behind the trim (behind driver side seat belt linkage), in wheel well...and thought best to ask Rennlisters before I cause more damage. The male part comes from below...but where does it go from the speaker hole?
Thanks, as always for your help.
